How to Draw a Rough Line in Microstation
Hi all,
I need to draw a rough line in Microstation.  This rough line would resemble broken slab, maybe, or a rough floor surface, etc.  What is the best way to do this? Someone suggested using Smart Line to do this but I find that very cumbersome.  Is there a simpler and more elegant way to do this?  Thanks for all your help.
RE: How to Draw a Rough Line in Microstation
Do it the same as if you were drawing it by hand. Which is faster than having to set up a custom line style. If this is part of a cell, so. But if you really want to go to the Help menu and look up custom line styles.
Regards Namdac
