splits and solar energy!!!!!!!
I'm a automotive engeneer but I have to do an assignment witch comprises:
· Improving and completing test arrangement
· Making a simulation model to match
· Drawing up measuring protocols and performing measurements
The test arrangement comprises the following parts:
· Heat pump
· Solar collectors
· PV panels
· Buffer reservoirs
· Vertical ground heat exchangers
· A low-temperature emission system
The aim of the test arrangement is:
To find the cheapest possible space heating system with a net power input exclusively from solar- and ground heat.
This translates into a search for:
· The most appropriate configuration of the test arrangement
· Optimum correlations between:
v Dimensions of collectors and panels
v Heat exchanger power
v Heat pump power
v Size of buffer reservoirs
If some one can help me about this subject please do it!!!
advenced sincerly thanks,
holand
· Heat pump
· Solar collectors
· PV panels
· Buffer reservoirs
v Heat pump power
holand
