PDMWorks Dwg Files
PDMWorks Dwg Files
When using PDMWorks Advanced Server is it possible to export dwg files as pdf using triggers in the same way as you can export Solidworks Drawing files. Can it be set so that when you update the revision the file is automatically created.
bmc1974
bmc1974
RE: PDMWorks Dwg Files
Bradley
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
