dual vs single chain drive
I am wondering about the relative efficiencies of two different chain drive configurations for a three wheel recumbant style bike. The bike is pedal powered.
Currently a sprocket at the front drives a single chain that runs to the rear wheel. The chain runs "underneath" another idler sprocket so that the chain can run underneath the rider. The return chain is necessarily very slack.
The alternative which would be more convenient for the overall bike design is the have two seperate chains, one running from the pedal sprocket at the front to an intermediate axle which in turn drives the rear axle. Separating the drive like this would allow the chain to run underneath the rider a little more elegantly and simplify the bike design.
Is there any major efficiency losses in the second configuration compared to the first?
Thanks for any responses
RE: dual vs single chain drive
As in so much else with bicycles, not much is published, you'll probably be better off measuring it.
Cheers
Greg Locock
Mike Halloran
Pembroke Pines, FL, USA
The long slack span you now have sounds like a possible maintenance issue and failure (chain derailing) point.
In the interest of keeping losses down in the second scheme, try to keep the sprockets on the intermediate shaft as large as possible; 20 teeth minimum, 30 even better. This is to minimize chordal action, which is a major contributor to chain drive losses.
