Metals Compatibility
Are there any compatibility issues between brass and cast iron or ductile iron?
RE: Metals Compatibility
The answer to your question depends on application. Can you provide us with more information regarding your application?
We will place brass caps on either ductile iron or cast iron pipes that are cleanouts. The caps will be at the surface of a concrete paved area and the pipes will be below.
This should be acceptable.
If you were to be in our part of the world,you would not have considered brass,for it would be stolen on day one.
