Roark's "Singularity Function Bracket"?
In Roark, the section regarding flat, circular plates has a statement regarding singularity function brackets. It states:
"The singularity function brackets < > indicate that the expression contained within the brackets must be equated to zero unless r>ro, after which they are treated as any other brackets."
All of these equations have <r-ro>^0 such that if r<ro, then per the statement made in Roark, we must equate what is inside the bracket to zero. The problem then is trying to raise zero to the power zero which by any calculator I've ever owned is nonsense.
I've always assumed what they mean is that the expression is zero. Unfortunately that's not what they say. What they say, if taken literally, is nonsense.
Note that if r>ro then what is contained within brackets doesn't matter since it is always raised to the zero power and it then equals 1 and the entire expression is simply something times 1. It seems the use of these singularity function brackets is a very confusing way of presenting an if/then statement.
I wonder if I've made the correct interpretation or not. If r<ro, should the entire variable equate to zero, and if not what should it be?
RE: Roark's "Singularity Function Bracket"?
A quick google led me to the following site,
h
This gives what appears to be a comprehensive definition of the "singularity function". It includes the index as a part of the function (or, rather, of the family of functions), and specifically covers the case where the index is zero. This suggests that your previous interpretation has been correct, and the fault lies with Roark and/or Young for giving an incomplete definition of the function.
This would seem to put the issue to bed. However it assumes firstly that the above site is correct in its definition, and secondly that Roark/Young meant to use the same definition (even though they ended up with a definition that gives a nonsense result when the index is zero).
My copy of Roark (fifth edition I'm ashamed to admit), includes a more elaborate definition and explanation of the singularity function. It is in chapter 7, "Beams; flexure of straight bars", near the end of article 7.1, "Straight beams elastically stressed", in a subsection titled "tabulated formulas". Later editions of Roark have different chapter numbers at the very least, but hopefully they will contain the same paragraph somewhere.
This paragraph specifically states that <x-a>0 is the same as the "unit step function" (aka the Heaviside function). Thus it confirms what you have been assuming, and is consistent with the web site.
Cheers
Greg Locock
Greg, please check 0^0. I believe the answer isn't 1.
The sinularity function most often expressed in this reference is the step function. written with the bracket notation <x-a>, which is defined as having value of zero if x<a and value of unity if x>a. The indeterminate value when x=a is no cause for concern, because either it is multiplied be another function that will have a value of zero when x=a or it will pretain to a concentrated load or moment where this indeterminate condition has been accepted in exchange for the simplicity of a load at point concept. Intergals of the step function, such as the ramp function<x-a>^1 and all others expressed as <x-a>^n, are defined as having a value of zero if x<a and the normal functional values (x-a)^n if x>a.
Cheers
Greg Locock
The example I found on the net was;
2x3 = 1 x 2 x 3 = 6
2^3 = 1 x 2 x 2 x 2 = 8
Therefore;
2^0 = 1
and 0^0 = 1
DW
For all practical cases zero is more 'zero like' than loge (x) is 'infinite' so the zero wins. Eat your heart out Cantor.
And that is about all the higher maths I can cope with today! I'm sure the Wolfram site has more.
Cheers
Greg Locock
Ref: Roark's formulas for Stress and Strain, Seventh Edition, pg 457 - 459
"0-" approaches true null from the negative side.
"0+" approaches true null from the positive side.
"null" is used where absolute true null is intended.
Most equations require the distinction, but presume a default condition.
As for computers, well, the truth is that there is no such thing as "zero" here. The result of a computation could be anything less than the arithemetic precision to be output as "zero".
1 - a^b is discontinuous on either side of a=0 but continuous on both sides of b=0.
So the pattern 0^x does not shed much light on the question but the pattern x^0 seems pretty unambiguous... always 1.
2 - Further the rules of exponentiation dictate that x^0 will be the multiplicative identity (1).
3 - I don’t see any rule suggesting 0^x must be 0. Intuitively we think that any number of multiples of 0 must be 0.... but remember exponentiation starts counting at the multiplicative identity (1) and if the exponent is 0 you haven’t multiplied by 0 yet.
Just my two cents on the esoteric question of the day. I don’t know anything about Roark.
can't see your point.
<r-ro>0 is simply a step function that's zero for r≤ro and 1 otherwise.
There are two reasons for using such a formulation in place of an if-then statement:
- it can be compactly written inside a formula
- it is a special case of the more general <r-ro>n that's used in other sections of the Roark.
prex
http://www.xcalcs.com
Online tools for structural design
Note that this isn't exactly how the singularity function brackets are defined in Roark. (read first post carefully)
corus
if something is raised to the zero power it is equal to 1,
then what's the point of the term in Roark ?
would it make more sense to interpret this term as a switch ...
= 1 if r>r0
= 0 if r<r0
actually this is the way i read Roark 7th ed pg 429
Here is another math forum.
http://planetmath.org/
it's a 1 or a 0 you multiply by, depending on the location where you're at. read the explanation of the step function notation (pg 94 of 5th ed)
Remember - Roark is for regular engineers designing/building real things, not mathematicians contemplating their belly-buttons
0^0 is mathematically treaded as indeterminate, one of the classical forms designated under L'Hospitale's Rule in Series Analysis. These forms become typical in series expansions around singularity points in differential equations solved by the Power Series Method.
PanDuro correctly shows that approaching the singularity point from the right or left offers a notion of jump discontinuties. As such, zero is any number becoming infinitely small, not necessary "nothingness". Afterall is not the multiplicative inverse of zero an entity exceedingly large? How do we quanitfy infinity, is it not just a large number? Then zero is a concept of nothingness and not a number.
In the singularity function analysis, the bracket is treated as zero if it's contents are negative, INCLUDING values exceedingly close to zero. Otherwise, the bracket and exponent take on their mathematical value.
Good job PanDuru.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
Principal
Both of my calculators, and Excel, spit the dummy. There again they can't solve (-4)^(2.5) which you can do in your head.
Cheers
Greg Locock
Cockroach - What is limit as x->0 of x^0?
Lim x->0 of 0^x is indeterminate (depends from where you approach)
Lim x->0 of x^0 is well-defined (it is 1)
Sorry to beat a dead horse. There is room for interpetation on the question of 0^0 and more than one right answer depending on the context.
h
The Devil is definitely in the details... but I think I was basically wrong in emphasis, although 0^0 is often taken as 1, /and you can derive useful results by doing so/, there is no good proof that this is an acceptable shortcut.
From the Wolfram article:
a^0=1
for all a that are non zero
so we'd predict 0^0=1
but
0^a=0
so we'd predict 0^0=0
That thread you've found gets off on the wrong foot. You can't divide by zero, ever , in normal maths. That is the RULE. http://mathworld.wolfram.com/DivisionbyZero.html
Cheers
Greg Locock
corus
