Motor size?
Motor size?
When there is no nameplate on an electric motor is there anyway to find out its KW,Amp rating etc
Guru,Botswana
Guru,Botswana
RE: Motor size?
If it is running happily in an application just measure the current, make a power factor estimate and do the math.
If it is sitting on the ground in front of you... You will have a much bigger problem.
What have you got?
Keith Cress
RE: Motor size?
Guru,Botswana
RE: Motor size?
Eng-Tips: Help for your job, not for your homework Read FAQ731-376
RE: Motor size?
If the unit is built to standard. Shaft measurement will do, mounting dimension you'll then find the FRAME # but it's just an approximation.
Better to run the machine and test it as itsmoked said.
