Trailing zeros?
Trailing zeros?
I'm working in WF2.0.
I brought up an old drawing to make a new version of this part.
I'm adding some holes, and dimensioned them in sketcher as 1.000 dia. on a 10.000 base circle.
the drawing has something set so that it doesn't show trailing zeros. These 3 plc. decimals really are required to convey how tight to hold the machining tolerances. I searched and can't find a setting or config. option to change this. I even have looked thru a couple of the lists of hidden configs I've downloaded.
This file may have been created a few years ago in 2001 originally, and brought into WF, if that makes a difference.
Thanks a lot in advance for any help.
David
RE: Trailing zeros?
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
RE: Trailing zeros?
You can manually change it to 3dp by selecting the dimension(s), right clicking, hitting Properties, and then changing the "Number of Decimal Places" field to 3.
I have a few mapkeys on my system set up to do this automatically for 0 and 1 dec places. A quick way to do a whole sheet is to change the seletion filter (bottom right) to dimensions, selecting across the whole sheet, and then running the mapkey. Note: this will override the default settings above.
AFAIK the accuracy comes from the dimensions in the model, so it depends on the settings they had for the above config options at the time of model creation.
Cheers
RE: Trailing zeros?
lead_trail_zeros STD_DEFAULT
lead_trail_zeros_scope ALL
RE: Trailing zeros?
I tried to type that in the properties and it doesn't show up as a valid config.
David
RE: Trailing zeros?
The control of trialing zeros (or not showing them) is often a result of ISO dimensioning schemes.
Steve
http://www.sprdesign.com
http://www.3dlogix.com
