change material
change material
That is supposed to be a primitive question , but just to make sure. In order to change material properties during analysis, i use the Field option?
I'll be using soil step,followed by general static step,so is that the only method to change material properties during analysis?
what does the linear material change means? does it mean material properties will change during the application of steps?
