Another stacked balloon question ...
How do you select a part, for inclusion in a balloon stack, when you can't see it? I've tried "select other" with less than good results. I've also tried "3D Drawing View" but the balloon stack disapears. The only reliable way that I've found is to put some sort of cut into my assembly, so I can see all the parts in the drawing view I'm ballooning, then delete or supress the cut after I create the balloons.
Does anyone have a better solution?
RE: Another stacked balloon question ...
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
ctopher, I agree with what you say, up to a point. However, there are times when calling out a hidden part with a stacked balloon is all I really need. For example, a flange with an o-ring, you can see the flange and its balloon and the placement of the o-ring is not in question.
