Once-Through Cooling
I know that at one time, one of the International Codes contained a prohibition on using potable water for once-through cooling of equipment.  I recently told someone that I needed to connect their equipment to the building cooling system because once-through cooling was a violation of code (and a waste of city water).  But now I can't find anything about it in either the mechanical or plumbing codes.
Anyone know where this is?
---KenRad
RE: Once-Through Cooling
Isn't the violation if you tried to use the potable water after passing through the heat exchanger? With the once through system you would probably require a backflow preventer.
walkes,
Yes, the IPC prohibits this, which they call reutilization.  But I was talking about the use of potable water for cooling, then discharging to drain, which is referred to as once-through.  I seem to remember seeing that this was somehow prohibited or at least restricted to certain conditions.  But I can't find it now, so maybe my memory is making things up.
---KenRad
I think it might be a local bylaw depending on the area you are in, for water conservation purposes.  Given the state of the environment, I suggest that as engineers we should be promoting better environmental practices and even if potable water is "allowed" to be used for a cooling process, it should be avoided, and alternate means should be found- rain water collection tank as a cooling water source, closed loop chilled water or closed condenser water loop to an outdoor fluid cooler, etc.
Is the potable water metered?  If so then is might be a pretty hefty operating cost depending on the average yearly flow rate of that nice expensive water being dumped into a drain.
Sure, wasn't there mention on NPR a couple days ago about circus clowns being in violation of water conservation rules in some county for using their squirting flowers?
TTFN
