Close corners on sheet metal bends.
I am creating sheet metal doors. I am flange bending the four sides then entending the walls up and out.
Is there a way to completly close the corners. Everything I try leaves a small hole at the corners.
I am using Pro/E Wildfire 2.0
John K.
John K.
RE: Close corners on sheet metal bends.
Erik
Ben Loosli
Sr IS Technologist
L-3 Communications
