multiply circuit?
multiply circuit?
multiply circuit?
I have a /3 then /5 circuit (4017, 74HC90) for reading Rev/S on a pump shaft.  Now I have a new indicator which cannot be changed, that must see 4 signals per revolution.  The exciter is 35-1 teeth.  Can I multiply by four?  I apologize, I have not had formal training in this field.
Thank you very much
RE: multiply circuit?
Yes, you can, using e.g. 7497 rate multiplier.
If I understand, you divide the output by 3 and then by 15
-- i.e. alltogether by 15 --.
In this case you could get more evenly distributed pulses
by taking the signal before dividing by 5 and skip
one of five pulses.
Do you get 35 pulses/rev ? in this case you must divide by
7 and 5 -- i.e.35 -- not by 3 and 5. In this case it would
be better to divide by 9-9-9-8.
If you need more, E-mail more info
<nbucska@pcperipherals.com>
It is indeed /7, not 3.  My fault.  I thank you very much for your help.  I will look into the rate multiplier.  Thank you.
It is better to use input/7 and do a divide by 9-9-9-8.
This will give to you allmost evenly spaced pulses.
Want a sketch? Send FAX#.
I sent you an email.  Let me know what you think.  My fax is in there so if you have time, a sketch would be great.
Thank you
