Question about the initial stress condition in ABAQUS
As we know, we set the parameters Ko in abaqus to control the initial stress condition(horizontal stress and vertical stress). my problem is whatever Ko values you use. when you get the inital condition stress ditribution, i mean check the distribution of vertical stress and horizontal stress, the ratio always gives me unity (horizontal stress/ vertical stress=1). does any one else meet this sorts of problems. if you did, please give me some tips. Thanks a lot.
Thanks.
Hongwei
Thanks.
Hongwei
RE: Question about the initial stress condition in ABAQUS
For using initial gravity load, I always use:
*INITIAL CONDITIONS,TYPE=STRESS,GEOSTATIC
EBODY,-21.,0.,-1.,1.,0.5
The last number (0.5) show the K0-value. And I found the intial condition of horizontal/vertical stress ratio is correct, exactly 0.5.
hope this could help.
sendy
Thanks for your reply.
Hongwei
I told u man change poisson ratio from 0.499 and it'll work
