how to access msaccess2000 by visual basic 6
If I use the late binding then I don't need to use MDAC reference?
CODE
   Set cn = CreateObject("ADODB.Connection")
Quote:
Compile error:
Invalid outside procedure
Is this the correct way of presenting it (do I have to use sub and end sub)?
CODE
    Dim connectionString As String
    Dim query As String
    Dim cn
    Dim cmd
    Dim rs
    Set cmd = CreateObject("ADODB.Command")
    Set rs = CreateObject("ADODB.Recordset")
    query = "SELECT text_data from bible"
    connectionString = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\Inetpub\wwwroot\wheelofgod\kjv.mdb;User Id=admin;Password=;"
    cn.connectionString = connectionString
    cn.Open
    cmd.ActiveConnection = cn
    cmd.CommandText = query
    Set rs = cmd.Execute
    While rs.EOF <> True
        MsgBox (rs(0))
        rs.MoveNext
    Wend
    rs.Close
    cn.Close
RE: how to access msaccess2000 by visual basic 6
Yes, you have to put this code inside of the Sub/End Sub and then call the procedure at the appropriate time.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
Let me back up a minute.  You need to take into account the scope of these objects.  Where and how you declare the objects defines that score, and they probably should declare inside a module with global score.
You should also include code to close the connections and release the objects before terminating the application.
Good Luck
Ok thanks. The sub did it. But I didn't understand your last posting. I'm new at scripting with VB 6.
