Really Slow Loading
Really Slow Loading
My problem and question is how come that a small file like this one takes 1-2min to load (www.apeldesign.com/GEN NOTES.dwg)-157kb
and files much bigger takes a secound
is there anything I can do about it ?
is it takeing the same time for you guys?
thanks alot for your help
this is my system info
[System Summary]
Processor x86 Family 15 Model 2 Stepping 9 GenuineIntel ~2792 Mhz
Item Value
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 2 Build 2600
OS Manufacturer Microsoft Corporation
System Name DESKTOP10
System Manufacturer Dell Computer Corporation
System Model Dimension 4600i
System Type X86-based PC
BIOS Version/Date Dell Computer Corporation A09, 2/20/2004
SMBIOS Version 2.3
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Locale United States
Hardware Abstraction Layer Version = "5.1.2600.2562 (xpsp.040919-1030)"
User Name DESKTOP10\Administrator
Time Zone Pacific Daylight Time
Total Physical Memory 1,024.00 MB
Available Physical Memory 763.63 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 1.90 GB
Page File D:\pagefile.sys
[Hardware Resources]
[Display]
Item Value
Name NVIDIA Quadro FX 3000
PNP Device ID PCI\VEN_10DE&DEV_0338&SUBSYS_01C210DE&REV_A1
\4&1246FE7B&0&0008
Adapter Type Quadro FX 3000, NVIDIA compatible
Adapter Description NVIDIA Quadro FX 3000
Adapter RAM 256.00 MB (268,435,456 bytes)
Installed Drivers nv4_disp.dll
Driver Version 6.14.10.8167
INF File oem1.inf (nv4_WSApps_NV3x_DOEB section)
Color Planes 1
Color Table Entries 65536
Resolution 1024 x 768 x 60 hertz
Bits/Pixel 16
Memory Address 0xFD000000-0xFEAFFFFF
Memory Address 0xE0000000-0xEFFFFFFF
IRQ Channel IRQ 16
[System Summary]
Item Value
SMBIOS Version 2.3
[Display]
Item Value
\4&1246FE7B&0&0008
Color Planes 1
Bits/Pixel 16
IRQ Channel IRQ 16
RE: Really Slow Loading
http://www.cadxp.info/sujetXForum-624.htm
Don't forget to report back if you get your problem resolved. It may help someone else in the future.
Good luck
thanks
what else should i do?
I am no expert so try to search around for threads like this http://www.eng-tips.com/viewthread.cfm?qid=123823
I cant check out the drawing at the moment. Are there any Xrefs on the drawing if there is that may be part of the problem. There are a few other good websites for cad give them a try post the question there are some real bright sparks out there.
Good luck
"Everybody is ignorant, only on different subjects." — Will Rogers
