Any ideas for correcting this error message?
ODB Field Frame Number 13 of 20 requested intervals at 3.250000E-01
10759139 3.266E-01 3.266E-01 05:26:28 2.642E-08 1110 1.335E-05
10815453 3.283E-01 3.283E-01 05:28:28 2.486E-08 150 1.683E-05
10871377 3.300E-01 3.300E-01 05:30:28 2.294E-08 1080 2.047E-04
10926681 3.316E-01 3.316E-01 05:32:28 2.810E-08 1110 1.329E-05
10981282 3.332E-01 3.332E-01 05:34:28 2.445E-08 1198 1.977E-05
11032560 3.348E-01 3.348E-01 05:36:28 2.268E-08 1198 5.364E-05
11087557 3.364E-01 3.364E-01 05:38:28 2.138E-08 1200 3.748E-04
***WARNING: In element 1200 of instance POWDER-1 the ratio of deformation
speed to wave speed is 0.30479 at increment 11143084. See the
message file for further information.
***ERROR: Excessive distortion of element number 1200 of instance POWDER-1
***ERROR: There is only one excessively distorted element
***ERROR: The ratio of deformation speed to wave speed exceeds 1.0000 in at
least one element. This usually indicates an error with the model
definition. Additional diagnostic information may be found in the
message file.
Chris
message file.
Chris
RE: Any ideas for correcting this error message?
Could be any number of things to be honest - best to look at the element in Viewer and try to figure out why it is distorting so badly.
Also, there may be a sudden increase in velocity on the nodes attached to that element that is causing an instability. Could be that the load is being applied too quickly?
Martin
