Lateral & Angular Spring Rate
Does anyone have the formula for calculating these?
RE: Lateral & Angular Spring Rate
These are a function of the equipment design and materials. Expansion joint manufacturers test and publish their respective spring rates as well as the effects of temperature on these properties.
"Lateral & Angular Spring Rate" of what?
to metal bellows or expansion joints
