Thrust Blocks
3
Thrust Blocks
Thrust Blocks
Does anyone have the definitive solution for the determination of pipe thrust forces and the design of thrust blocks?  I have seen many undocumented solutions but no definitive reference.  I am referring to fluid flow in steel pipes.
Thanks for answering.
RE: Thrust Blocks
For thrust blocks, even with steel pipe, I suggest using "Thrust Restraint Design For Ductile Iron Pipe" from the Ductile Iron Pipe Institute. See pages 2 thru 6 of this link
http://www.dipra.org/pdf/thrustRestraint.pdf
Use of thrust blocks assumes that the pipe itself makes no significant contribution to restraint - therefore the pipe material (steel, DI, plastic, fiberglass, etc.) is irrelevant.
www.SlideRuleEra.net idea
RE: Thrust Blocks
As an alternative you could look at the following CIRIA Report 128, unfortunately though, its not free.
"Guide to the design of thrust blocks for buried pressure pipelines"
http://www.ciria.org/acatalog/R128.html
