Saving an Autocad file which is 'Write Protected'
I have just re-used an old autocad drawing, re-numbered it and hit the sace button.A message has come back saying this drawing is 'write protected'and cannot save. How do I remove this setting.
RE: Saving an Autocad file which is 'Write Protected'
http://www.resorucecad.com ~ for your CAD solutions
"Everybody is ignorant, only on different subjects." — Will Rogers
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Albert Einstein
if everyone helps everybody the world will be a better place
