AD-converter
AD-converter
AD-converter
we have a AD-converter (type tlc549cp) .
the code for reading this ADC in Visual Basic.Net is:
private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Dim i As Integer
        i = OPENCOM("COM1,1200,N,8,1")
        If i = 0 Then MsgBox("COM1 niet beschikbaar")
        Timer1.Interval = 1000
End Sub
Public Function AD()
        Dim i, bitwaarde, bitpositie, meting As Integer
        RTS(1)
        DELAYUS(10)
        RTS(0)
        DELAYUS(50)
        meting = 0
        bitwaarde = 128
        For bitpositie = 1 To 8
            If DSR = 1 Then meting = meting + bitwaarde
            DTR(1)
            DELAYUS(10)
            DTR(0)
            DELAYUS(10)
            bitwaarde = bitwaarde / 2
        Next bitpositie
        AD = meting
End Function
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
        Dim spanning As Double
        spanning = AD() / 255 * 5
        'spanning word in textvak gezet
        Text1.Text = CStr(spanning & " V ")
end sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Timer1.Enabled = True
End Sub
i have created a program in LabVIEW, it looks exactly the same, but it doesn't works, it gives constantly the same voltage.
