Please help. Unsolved AutoCad & VBA problem
Please help. I have an AutoCad drawing, which has a lot of Xref (external reference - collecting drawings from another location/folder in my computer and then posting them into a single AutoCad drawing). Recently, I renamed some Xref files and moved them into a different folder/location.
When I reopen my AutoCad drawing, some of my drawings cannot be displayed because some Xref are missing or not loaded (due to renaming and moving them into a different folder/location, which Autocad don't know how to locate them)
So currently i start fixing the Xref path by browsing each file to the correct name & path of the new location.
For a lot of Xrefs, this is very painfull. =) I am just wondering if there is a VBA code, which can help me fix this Xref issue. My first thought is to list all Old Xrefs (drawing name & its location) and New Xrefs in 1 folder, plug them into a VBA code, and run the VBA code in the AutoCad. Therefore, the program can match/compare the old and new Xref name & its location and automatically repath the Xref for me. Please let me know if this can be done. This really helps. Thank you in advance for your help.
Yudha
Yudha
