Base Support
Base Support
Base Support
I need to find out what is the best equation to use to determine the thickness of a rectangular supoorting base that is 220 inches by 110 inches that can carry a load of 20,000lbs. Thanks everyone
RE: Base Support
Concrete, tubular steel, channel steel, cargo net, timbers, ice, etc.    Not sure what your specific requirements are; however, I can think of lots of possible numerical solutions that may or may not be suitable for your problem.
RE: Base Support
i need to figure out what is cheapest. the rectangular base will sit flat on the floor without any beams supporting it from below. I'm thinking probably steel.
RE: Base Support
What kind of load?-- concentrated, distrubuted?
RE: Base Support
If it's evenly distributed, that's about 120 lb/sqft load on the floor, so it better not be above ground floor.
Also, note that 1-inch thick steel plate that size is already about 7,000 lb, bringing the total load up to about 160 lb/sqft on the flooring.
TTFN
