Send to->zip?
Send to->zip?
Is there an easy way to save an assembly in a zip file from solidworks? They have this with photoworks and also in the solidworrks RX.... How do I do it with just swx?
Tim
Tim
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Send to->zip?
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: Send to->zip?
File, Find References
this generates a list of files used in the assembly. There is a Copy Files button on the form that pops up which allows you to copy all the files to where ever you want. I'd recommend an empty directory for this. You can then zip up the entire directory.
This will not, however, copy any drawings.
RE: Send to->zip?
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP4.0 on WinXP SP2
