Photoworks - mateirals are not being transferred to part faces
Is anyone else seeing a problem with when you select multiple faces or the entire part and add a material to that part using lets say Miscellaneous\fabric\Satin black - I can't get those type of materials to show up on my model... they don't turn the color I specifiy.. I have messed with the options but still cannot get this to work. Can someone else test this and let me know if they can use it or not. I can then debug it further.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: Photoworks - mateirals are not being transferred to part faces
It wasn't important, so I didn't go further with it.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com (updated 5/01/06)
SW 2006 SP 4.0
I could repeat your problem to the t, but only when I have Photoworks->Options->System Options->Use Solidworks Materials checked. Otherwise, everything seems to work fine.
Best regards,
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
What made my problem difficult to resolve is that after unchecking the Use SW Materials box, the problem didn't resolve. It also didn't resolve after a rebuild. I had to get into the material editor, make a subtle change, change it back to what I needed, and then the appearance updated. Very difficult to track what does what. Perhaps we could use an interface update?
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
