Pulling dimensions into a note
Forgive me if this has been answered before, I couldn't find it if so.
I have a dimension (from a fillet) on a part which I want to show up on a drawing.  Solidworks will not pull this dimension automatically (assumably because I do not have an orthogonal view to see it).  Since it's a fillet I'm content to have a note pointing to the appropriate area, but how do I callout for the dimension (from the part) so SWx will update if it changes.
I can hardcode the number, but that won't update, and since the dimension isn't present anywhere else on the drawing I can't match the syntax of other dimensions.  Also, the syntax for a design table parameter doesn't work either.
Am I missing something obvious?
RE: Pulling dimensions into a note
Try adding a view which does show the fillet, link the dimension in the note, then delete the view (or move it offscreen).
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
If you follow CBL's path you can't delete the extra view, you must hide it.
Fillet dimension will also sometimes transfer from view-to-view using the ctrl-drag-n-drop method. Then you can delete the extra view.
Remember...
       "If you don't use your head,
                   your going to have to use your feet."
I just drag the view off-screen whenever I need a workaround like that.
Flores
SW06 SP4.1
You could do this in a design table.  You can create a custom property with this dimension ($prp@R1 for example) within the design table and link it to the cell that calls out this dimension.  You can then link the note to that custom property.
SolidWorks 2006 - SP3.0
UG NX3
Pro/Engineer Wildfire 2.0
GTCadGuy - beware of not updating design tables with this method.  I've been burned before by not updating design tables in which Excel calculates a custom property based on dimensions.
With 2006 you can have custom props that are directly linked to dimension values without using a design table.
handleman,
Thanks for the heads-up.  I usually edit the design table in a new window within excel to make sure that all my cells calculate correctly.
I was not aware that you could link a custom property directly to a dimension.  Now that I did a little searching on the subject, that is what I would do in this case.  Pretty simple to do in fact.  Create a new custom property, when asked for value/expression, click on the dimension and it adds the link.
UG NX3
