sheetmetal- dimple die how to??
Newbie to inventor here, hope this isnt too basic. :(
trying to figure out how to create this sheetmetal feature.
i need to create a small hole that is dimple died.
basically its opening is .072, height is .035 with a major diameter of .100, in .0095 stainless.
HowTF do i do this?? :confused:
edit: i've made a little progress.. i think.
other than i put it on the wrong side..
so now i have this dimple, but its not really a dimple.. more of an extruded feature....
how do i get a true dimple in here?????
RE: sheetmetal- dimple die how to??
I would think you could revolve a sketch, cutting or adding, but I don't know what'll happen in the flat pattern (if that matters to you).
Check out the punch tool.  It will not flatten, but I think it's what you're looking for.
