2.0 x 0.15 mm terminal
Does anybody know of a solderless terminal that will slide onto a 2.0 mm x 0.15 mm tab (6.2 mm long)?  So far I haven't found any smaller than 2.8 x 0.50 at Molex or Amp/Tyco.  This is for an LED contacts on the back of an E-switch R1966.  E-switch doesn't know of one.
I expect I may need to solder the wire to this terminal.
Thanks.
