Initial Conditions, void ratio
I am perfroming a contact analysis with a porous material and I get a error that reads "Permeability is specified on 20 elements but the initial void ratio is not defined. Use *initial conditions to the value. The elements are identified in element set ErrElemPermNoInitVoidRatio."  I have tried to enter it in the input file but I then get a return that the node set is not active.  How do I determine the name of my node set in the input file?
RE: Initial Conditions, void ratio
You can't, but you can view the node set in Viewer.
corus
