EvapCo Operation
EvapCo Operation
Dear All,
How do we operate Evaporative Condenser? My colleages insists in operating all the circulating pumps of 5 evapCo units even though the a couple of Evapcos are on standby, meaning the fans aren't operating. They argue that scaling would occur if the tubes (ammonia inside) are allowed to dry up. Whats your take on this?
Gladkenn
Gladkenn
RE: EvapCo Operation
Turn the pumps off and see what happens over a week or so.
If your climate and your duty cycle is such that 1) you have a remote sump some distance from the condensers and 2) your capacity requirement increases to near-100% very quickly, you may run into discharge pressure problems and compressor jackedet or thermosyphon oil cooling problems if you try to operate without the water "already at" the condensers.
Paralleled evap condensers are always going to have some minimum refrigerant flow. So, if you shut water flow off frequently on a particular condenser, you will tend to "soft scale" the coil. If you happen to be in a season where there is a lot of airborne debris (maple keys or poplar bolls or even sawdust) keeping the water flowing may prevent plugging the nozzle deck or the underside of the eliminators.
You can also encounter strange water treatment scenarios as well as de-passivation of the galvanizing on your coils by letting a single condenser's coil alternately go from wet to dry....That dependent to a large degree on your makeup water content as well as bleed rates and water treatment intensities.
The accepted generality is: if you can live without the water flow for an extended period, like days, take it out of the sequence; if its going to start today, you might as well start it this morning.
