Development of Rebar
What is the difference between development and embedment of rebar?
Thank you!
RE: Development of Rebar
I wonder if you mean envelopment? What is the context.
ACI 318 Chapter 12 refers to Development and Splices of Reinforcement
Development:  The length required by code that will ensure that the rebar itself will fail prior to the rebar pulling out of the concrete (i.e. loss of bond).
Embedment:  The actual length of bar that is in the concrete.
So you could have a bar that is embedded 8" into concrete, and need 12" to develop the full bar strength.
