Curve Through XYZ Points
I am trying to use SW to design a ship hull. I have a list of points (forming spline curves) where the surface of the hull should lie on. I can insert them using the command "curve through xyz points, reading from a text file". The problem is that I am using the command for each curve. Is there any way to read (insert) all the curves from a single *.txt file?
Thanks in advance
RE: Curve Through XYZ Points
Try a search here for XYZ. It's been discussed before.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
Read the help it describes how you are suppose to set up your text file.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I have tryed a search as you sugested "ctopher", and i have found a macro that reads from an txt file, and creates a cloud of points. Thanks for the sugestion.
I have no experience programming macros, so mi question is: is it possible to program a macro that could as well read the txt file and create a spline curve, based on the previous points, or creates the same spline curves using the "cloud"?
No, each curve will have to have it's own text file.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
