Axisymmetric Modal analysis?
Hi all,
I am in the process of learning to run an import analysis after a dynamic, in order to run a frequency extraction. The problem, is the dynamic step is so complex that the model must be axisymmetric. My question is, can an axisymmetric model be used for a modal analysis or can the axisymmetric model be made 3D to get the right eigenvalues and eigenvectors.
Thanks to all,
Chris
Thanks to all,
Chris
RE: Axisymmetric Modal analysis?
Take a look at section 10.3.1 in the ABAQUS Analysis Users Manual. This tells you how to create a 3D mesh from an axisymmetric mesh - might get you what you need
Martin
