Can NX4 save to NX2?
Is it possible to save to a lower version of NX from NX4? I did not see it in the normal save as function.
"Everybody is ignorant, only on different subjects." — Will Rogers
RE: Can NX4 save to NX2?
In the version of NX where your model is currently accessable, open the file and go to File/Export/Parasolid... and in the version setting you can select the "target" version of UG/NX that you desire. Once a model has been exported, start a session of your older vresion of NX and open an empty file and perform a File/Import/Parasolid.... and import the Parasolid modeling into the empty part file.
Note that starting in NX 4, you will be to open a Parasolid file directly into NX using the regular File/Open... dialog.
John R. Baker, P.E.
Product "Evangelist"
NX Product Line
UGS Corp
Cypress, CA
Phone: 714-952-6032
FAX: 714-952-5758
John.R.Baker@ugs.com
