Swing Check Valve Top Gasket
Hi Guys,
I have a 10" swing check valve which leaks from top joint where top cover is bolted to the body. This valve is as per BS 1868 and this gasket is of Graphite material. Can anyone advise the dimention of this gasket?
Cheers
