MacP strut design
MacP strut design
I'm currently working on designing a front spring and strut package for a MacP car (S13 240SX). I'm trying to keep costs down and would like to go with a bilstein take apart shock. I know that I need to account for side loading and bending in the strut. And I was considering using a shock in an inverted setup with a steel or Al sleeve on the bottom that would slide with the shaft and go around the body of the shock to help deal with these loads.
I was wondering if anyone has any insight on this? I've seen several other setups for this car that don't use an inverted strut and don't know how they take into account the side loads. I mean that could do it internally but based on the size of the shock and the shaft displacement it doesn't look like there's any room for an extra internal guide. The shaft diameter might be a little larger in the front on some setups, but is that enough? I also seem to remember that the stock struts for this car seem to apprear very similar to the rear shocks in terms of shaft diameter.
This setup would be used for a track car, so loads would be an issue, but long-term (more than a race season) durability isn't as important. I just don't want to have something that will need to be rebuilt after every race.
I haven't done any of the loading calcs yet, I'm still in preliminary stages for this design and am really just trying to gather more information.
So I guess my main question is would there be any problems using a shock in a strut configuration? I would like to make an inverted strut to help with the side loads, but is it necessary? And does anyone know what type of extra support is designed into OE or aftermarket struts versus similarly sized shocks?
Tim
Tim
RE: MacP strut design
Cheers
Greg Locock
I'm going to keep looking around at other shock companies, but I would like to keep costs down that's why I'm trying to stay away from some of the other big names.
I wonder if I could fit a bearing and seal into the bilstein damper. I know it wouldn't be as good as having one on the piston as well, but it might help out enough especially with the shock inverted.
I'll take a look at everything when my brother's shocks get here. I'm using the same shock for his car that I would use for the MacP setup if I decided to try it, so at least seeing his I would have a better idea of what loads it shoudl be able to take and what else I would need to do to use it as a strut.
The design loads on a track car are less than on a production car. I suggest you check with Bilstein, the side loads that can be developed in a MacP setup are far in excess of those that a conventional /shock/ sees. According to my sources additional linear bearings are used both at the upper seal, and at the piston. That being said I'm sure Bilstein make a take-apart for a MacP.
Try a European rally car parts dealer, I'm sure their experience with the Focus and many other small cars will be much more relevant.
Cheers
Greg Locock
Having said that, there are many strut cars using coil over conversions and various front strut cartridges with strut rod diameters down to 5/8". A good resource that I have used on many ocations is Jay Fizer at Koni NA
859 586 4100 X334. He can tell you right off what will work with your setup.
Good luck
Dave
I mean this is mainly for a race car, but I would also like to have something that would be strong enough to handle occasional street driving. I guess more in terms of durability.
Thanks for the contact, I will give Jay a call, I've been meaning to give Koni a call about their strut setups.
Tim
Tim
If you are going for functionality and affordability then I would not overlook the Koni 8611 shock. They have just started integrating digressive valving as standard (was an option before) into the shocks so they would be effective for dual usage. They offer multiple adjustment choices as well.
They are affordable as well, and with proper modification any 60mm spring can be used such as Eibach's race springs, or if you like to wait forever you can use Hyperco.
