"Structure is unstable" -Recommendations to find the problem
I am designing - for education- a 3D box truss of three similar(but not exactly the same) repeat sections.
If software is giving me the warning "Structure is unstable" .
Is there any systematic method of finding the problem?
The computer screen structure looks "good".
The software is "Dr. Frame".
RE: "Structure is unstable" -Recommendations to find the problem
corus
Good Luck
Thomas
Good luck!
-Brian
A systematic method of finding the problem would be to keep applying constraints until the model runs and then deduce the offending joint. Unless of course Dr Frame does frequency analysis when analysis of the mode shapes would be easier.
Cheers
Greg Locock
