How do you rotate latex interpreted text
I managed to get Latex intrpreter working by upgrading to version 7, but I can only get it to write horizontally. I want to write vertically for labelling the y-axis.
Michel Garcia
RE: How do you rotate latex interpreted text
How are you specifying the title for y-axis? is it using ylabel?  I its ylabel MATLAB should put it vertically. I think you can even force the angle using Rotation property.
Something like this
ylable(....,'Interpretor','latex','Rotation',90);
I used ylable(....,'Interpreter','latex','Rotation',90); and it made no difference what angle I input, the output y axis text was and is still horizontal.
Did you try placing some text in the plot
text(Xloc,Yloc,'TestString','Rotation',90);
AND
text(Xloc,Yloc,'TestString','Interpretor','latex','Rotation',90);
You can test whether the problem is with interpretor using above two.
goodluck
nodal
I just tried it now. Tex allows me to rotate using text(), but latex doesn't.
Then you can blame it on Latex interpretor..Huh!
I guess so. Now I have to find a way to place dots over my symbols some other way.
