Non-reusable clutch hubs?
I was skimming over a factory service manual for a Nissan 350Z manual transmission, when I noticed that Nissan recommended replacement of any clutch hub/sleeve pair removed from the tranny. I found this rather curious, and frightening from a cost standpoint.
Is it the splined fit b/t the hub and shaft, or something else that makes a used clutch hub/sleeve set unsuitable?
Dave
Dave
RE: Non-reusable clutch hubs?
It may be entirely conjectural; the factory probably has much less experience with really used transmissions than you do.
Mike Halloran
Pembroke Pines, FL, USA
