copy an assembly
copy an assembly
How do I copy an assembly to reuse in a new project.
Inventor 11
JeReMy
Inventor 11
JeReMy
RE: copy an assembly
OR the little addin called "iassembly" from Charles Bliss
http://www.cbliss.com/inventor/iCode/index.htm
OR if you are using the Vault, I believe that functionality is built in.
There is also probably a way to do it within design assistant, but the other ways are probably much easier.
Step:
1) Open vault for the first time.
2) RMC Add file Battery box assy.iam
3) Press OK, Then some box with Relationships and Inventor add-in I pressed YES.
4) RMC Copy Design
ERROR File Cannot Be copied
Could not locate associated project file in vault
Tried Pack and Go it's Not found or Grayed Out.
