Exploded Line Sketch on drawing
I have a drawing view showing an exploded view of an assembly with the dashed lines showing assembly order.  I have deleted a few items in the assembly and the items did dissappear from the drawing as well.  However the balloons and dashed lines (explode lines) did not automatically dissappear.  I was able to delete the balloons manually but the dashed lines can not be selected on the drawing or the exploded view in the model.
Looking for suggestions as to why this is happening....
BC
I come from a small town where the population NEVER changed.  Everytime someone got pregnant, someone left town.
RE: Exploded Line Sketch on drawing
You need to edit the explode line sketch and delete the route lines while editing the sketch.
It could be one of two things depending on how you created the lines. are they a sketch on the drawing view or are they from an "exploded line sketch"?
If you created them directly on the drawing, check to make sure if they are on the drawing view or on the drawing.
If you created them using an exploded line sketch then you will have to edit that and remove the lines
~BM
