annealing to eliminate warpage??
i have two parts the first is for simplicictys sake a CPVC bar and the second is a teflon 3/4 in rod. The bar has notches machines and the rod has a hole drilled through its length. The bar and the rod come out of the machine op with around a 1/32 bow. Some co-workers have suggested annealing to eliminate the warpage. What i know about annealing is that is it used to relieve stress to improve mechanical properties. I have speculaed that annealing could make warpage worse, as material shrinks and relaxes more???? Is this correct
RE: annealing to eliminate warpage??
Mike
