Plane on Surface is Offset?
I'm trying to create a plane on a cylindrical surface. I know, pretty straight forward. However, the plan is created offset from the surface, and I cannot determine why. Has anyone run into something like this before? Using SW2005.
Matt
Matt
RE: Plane on Surface is Offset?
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Matt
A "print-screen" image may help also. FAQ559-1100
In the attached image, the plane on the surface was created at the part level, while the plane offset from the surface was created at the assembly level. Both were created using the same technique discussed above.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
Matt
Can you reproduce the problem in other assemblies?
Flores
SW06 SP4.1
Thanks for the suggestions.
Matt
