Rectisol Cost Estimate
Does anyone know where I can go to get an estimate for processing 100,000 scfm of synthesis gas (containing H2S, CO2, and COS) to reach sub-ppm levels of sulfur in the gas?  This gas is 45% CO, 30% H2, 8% CO2, some H2O, and % level of sulfur.  Who supplies this type of scrubbing device? (I'm not sure of the supplier base, or I wouldn't ask such a question).  Is there some "rule of thumb" I can use like x$/1,000 scf of gas (gas at 30 atmospheres, but scf measured in 1 atmosphere, 59 F)
RE: Rectisol Cost Estimate
bonzoboy:
Contact the Bryan Research and Engineering company at www.BRE.com. They are an excellent choice for the type of process you seek.
Milton Beychok
(Visit me at www.air-dispersion.com)
Bonzoboy,
The Rectisol is a Lurgi AG licensed acid gas removal system. A general rule of thumb is that a Rectisol AGR is going to be about 4x to 5x the cost of a Amine equivalent system.
I am guessing it is safe to assume that you'll be sending this SynGas stream to some sort of Methanation unit or Fischer-Trops Unit?
Good Luck.
