Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Over the past year I have found your site to be EXCELLENT. Never have I been able to find so many answers to such vast problems and it is an excellent service..."
Geography
torpgal (Mechanical)
1 Jun 06 10:28
I have successfully meshed individual components -- featuring shell and solid elements.  However, when I mesh my entire assembly together, the shell components disappear and I am left with solid elements only.  Has anyone ever experienced this before or know how to fix the situation??  I am at a loss.
JohnAndrews (Mechanical)
8 Jun 06 11:44
What version are you using? This works okay for me in Wildfire 2.0, but before you mesh the assembly ensure that "AutoGEM - Solid/Midsurface" is highlighted from the top toolbar, not "Autogem - Solid"
13 Jun 06 15:43
I also have Wildfire 2.0 -- the Solid/Midsurface option is highlighted in AutoGEM, so I really do not know what the problem is.  I can compress the shells, and it indicates they are still there in the assembly, but when I run the mesher, it just leaves empty space where the shells should be, and puts the solid elements in place.
15 Jun 06 3:21
Difficult to see what the problem is - my WF2.0 cut is M170 - maybe your cut has a bug with mixed meshing.
Have you tried creating a couple of simple parts with mixed mesh, then assembling them and checking the mesh?
Do you have any simulation config.pro options which might be causing the problem?
Beyond that reportthe problem to PTC and see if they've come across it before.
Close Box
Join Eng-Tips® Today!
Join Us             Close
