assigned attributes in assembly navigator?
Hey, i've come up with another question
I am trying to figure out how to get a product definition (ie material spec) to show up under a "material" colum i created in the assembly navigator.
Like wise id like to get a finish note to show up under another colum i created.
Can anyone point me in the right direction?
Thanks in advance
Thanks in advance
RE: assigned attributes in assembly navigator?
Then in the ANT, when you use the user defined attribute column of Material, the value will show up.
Ben Loosli
Sr IS Technologist
L-3 Communications
When you say <whatever_material?, do you mean (for example) "<6061 Aluminum?" or just "6061 Aluminum"?,
or "<whatever_material?" ?
I tried with the "<whatever_material?" and thats exactly what shows up in the column, not the PD material
If typing in the part attribute for material and finish manually is the only option, then the product definition utility is basically useless for what im doing right?
looks like im gonna scrap the idea on NX, and stick to catia where it isnt impossible to do something so simple
Basically, I would think that you need to know how the attribute is coded and if it agrees with what the ANT is looking for.
Since I am there as a carryover by way of TCEnt, I don't have access to UG.
Ben Loosli
Sr IS Technologist
L-3 Communications
This is on NX2, btw.
