Edit Pattern Parts
Edit Pattern Parts
Is it possible to edit a Pattern Part feature in the assembly environment? Lets say I want to add or remove parts from the feature. Or do I have to delete the whole feature and create a new one?
Solid Edge V18 SP5 on WinXP SP2
RE: Edit Pattern Parts
But if you have a pattern using a hole command then you cannot remove an instance without deleting the hole itself.
Patrick
Thank you for your response. Actually I don't want to edit the profile of the pattern but which parts are patterned in the assembly environment.
Let's say I created a pattern of parts consisting out of a bolt and nut. Now I have added a washer to my design. How do I add this washer to the same pattern or must I create a all new pattern in my assembly.
Patrick
I thought that the "Edit Definitions" was only for normally placed parts.
