EPDM - unknown area (to me)
Please help me!
I recieved an RFQ, wich include some EPDM material.
Due I'm not a master on these type materials (maybe my english is not so good too - I'm working on it)I ask for your help!
EPDM to ASTM D200 4MAA 510 A13 B13 C12 - What does it mean?
Can you advise me a named material?
Gagar
Please help me!
Gagar
RE: EPDM - unknown area (to me)
Give it a try before you ask others to invest time.
What is an RFQ other than another TLA
http://ww
Cory
Etylenepropylenediene rubber (EPDM) "hence the acronym"
* Excellent resistance to weathering
* Good heat stability
Used on top of commerical roofs and used in automotive weather-stripping and seals, glass-run channel, radiator, garden and appliance hose, tubing, belts, electrical insulation, roofing membrane, geomembranes, rubber mechanical goods, plastic impact modification, thermoplastic vulcanizates and motor oil additive applications.
Business Card http://mech.e.tripod.com
__________________________________________
Cycle Heaven.......www.tailofthedragon.com
Gagar
the 4mAA 510 A13 etc....designates the type and class, each alpha-numberic group rates it as a different charateristic
If you have the ASTM D2000 it will explain it all.
