connection for precast shear wall
i want to know about the connections of precast shear walls that will resist wind and seismic load.
I mean the type of connection between two precasted shear panel that can act as a fixed connection and will translate the moment from mone panel to another safely.
i wish i will find a detailed answer to this important question
RE: connection for precast shear wall
If you follow their design procedure you'll prboably find that this connection is not necessary.
