Save a configuration as a new file?
Is there a way to save a configuration to a separate (unassociated) file? Thanks.
RE: Save a configuration as a new file?
Did you create configurations manually, or use a design table to create multiple configurations simultaneously?  If you created the configurations manually then just do a save as copy.  If you created a design table then just run the design table in a new part.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
Save as a copy, then open, break any references and delete the unwanted configurations is the only way I know.
Timelord
The above suggestions are the only way I know.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
Configurations of an assembly or part?  I don't know how to do this in one step, but it's easier if you want a configuration of a part than an assembly.  Look for Save Configurations at http://www.cadimensions.com/Resources/macros.cfm
As the name implies, it saves the configuration of a part/assembly in the same directory.  For a part, run the macro, and delete the ones you don't want.
Flores
SW06 SP4.1
It is an ejector pin sleeve. (sldprt) With every size in the catalogue. I will try the macro. This might be what i am looking for. Thanks.
